When I start my car, coolant starts to drip from a little hole in the firewall. I don't know what it is. It's next to the coolant and a/c line. It doesn't squirt out but a little at a time it started to drain all my antifreeze.
What do you guys think it can be?
How can it be fixed?
I'm still a noob to this BTW.
Super Moderator
You have a leaking heater core. You change it from under the passenger side dash. God write ups on how-to can be found searching.
You are also missing the rubber elbow that is supposed to be on the fitting you circled.
Thanks man. I didn't know exactly what it was called.
I have the elbow. Just took it off for a better pic because that's where it's leaking from.
