Hey buds...
(I'll keep it simple and quick...My coolant reservoir sprung a crack/leak) .... details:
Around 3 or so years ago, I purchase a replacement reservoir from eBay to replace my OEM that was developing cracks at the seams, plus the plastic was becoming brittle/chalky (firewall side edge, top) .... but here's the kicker.... the replacement developed the same cracks / discoloration, chalkiness on the edge (firewall side, top) too... see attached images... what do you folks think causes that SAME issue in both..? Is it a design flaw..? An over heating issue...?
I just ordered an OEM GM replacement ... So my plan is once it arrives to..... drain the block (via knock sensors)... flush it entire system, replace water pump (sensor), new 160 Stat ... and bleed it.... should I replace any other sensors, I'm I missing any in regards to cooling..? Attached is the sensor for my water pump ... I heard there's another on the side of the block...? If so GM# kindly ..?
(side note)
The 96' usually runs cool but lately, out of nowhere the temp shoots to the top then drops after a few moments ...got the 9C1 green hoses (all in perfect condition) and the annoying plastic "T" was swapped for a custom made metal one ... no leaks around the radiator and last I check, when i pulled the plug on the water pump sensor, both fans kicked on respectively ...
Thank you my friends ahead of time....
JESSE!
(side note)
JESSE!
