can someone take a picture or give really good detailed info on where the coolant temp sensor is? i need to find mine and replace it but before doing so i need to find out if its a 1 pin or 2 pin.
thanks a lot bro im going to take a look at mine tomorrow. i looked up the part number and i head u can use the 2 pin as 1 pin connector. im trying to save $ and use my ebay bucks lol.This pic is for an Fbody, but you can apply it to the Bbody if you look at it as if it's a pic of the RH cylinder head from below the starter, and in place of #1 spark plug, it would be the #8 spark plug. It's a one-wire sensor.
Your intake radiator side tank is probably cracked (the driver side). Check the upper ribs at the plastic tank on the outer side (the side opposite to the radiator hose).my cars radiator bust so it was overheating for a really long time cuz it had no water nor antifreeze so it was reading correctly until it like completely shut off like 20 mins or so i figured the sender/sensor got extremely hot for too long
dude stfu and kill yourself. You're annoying as f***maybe if you didnt triple post tis and used some basic gramer n enlish n stuff like puctuation so u dont run on then u might get some good answers.
Sorry, but OMFG!
nah my fan came loose and cut a whole into the radiator fins so it eventually bust and all coolant/water came straight out.Your intake radiator side tank is probably cracked (the driver side). Check the upper ribs at the plastic tank on the outer side (the side opposite to the radiator hose).
i have already swapped the radiator. Now im just trying to get my gauge to work because i can overheat and wont notice until i see smoke
I know I need to do a proper flush and bleed but I still need to get my temp gauge workingif you put a new radiator in, you need to bleed the system, then it won't overheat, unless you have other problems.
No dude, you are the annoying one. My point is that if you took the time to post your "urgent" problem in a thoughtful way and in the correct section (once), then you might get some more insightful help. And in case you didn't know it, there are rules about multi posting as you have done here, so "dude" why don't you STFU and stop assing up this Forum.dude stfu and kill yourself. You're annoying as f***
TBH I like being wrong sometimes, helps me learn things. I also like giving other possible solutions based on my own experiences. - Peterpcordes1979 said:Could also be an issue with the wiring or the sender, but most of the time when I've seen the gauge read dead cold unless it starts to overheat then it starts creeping up, it has been the physical gauge itself. - Peter
PETER you were WRONGGGGGGGG lol jk yeah but you were. we all learn something new on the forum but i finally changed it today and its back to normal. only paid like 5 for the sensor after coupon. its a 1 pin sensor.I didn't say it was not the sender, all I said was:
