Alright for those who have been helping me with my problem know that I had a leak and I just found it the other day and it was my temperature sensor for my coolant on my water pump. well I tightened down the sensor and there is still a small leak, I was wondering if there's suppose to be a o ring on the sensor when installed? because it's still leaking.
Did you use some teflon tape or sealant on the threads? I always put something on it. If so and it still leaks, check the WP housing directly underneath the sensor, I've had a rebuilt pump crack there before.
I hate reman water pumps, I'll never buy a rebuilt one ever again. I wish I bought the nice shiny Duralast pump for $150 it would of saved me a lot of stress and time... this is my second reman pump and no I didn't put teflon on it again, my friend put some on it the first time but it still leaked.
It shouldn't need more than moderate force on a wrench or rachet. Most likely, you don't have enough teflon tape on it or it was wrapped the wrong direction.
what's the amount of torque you need on your coolant temp sensor?
Not a lot. There is no spec because GM WP came with the sensor installed. But this is aluminum so don't tighten much. I would guess no more than 10 ft/lbs. A good pump and sensor will not leak. Tendency is keep tightening when there is a leak which can do more harm than good. Tape or sealant should do the trick on a new pump. A reman pump is a crapshot. You are dealing with a previously installed sensor of unknown tightness. My opinion: Always buy new.
which is the correct way?
You wrap the tape in the same direction as you tighten - usually clockwise. That's looking at the threaded end as you wrap. Looking at the connector end (or the head of a bolt) it would be counterclockwise. You will get the hang of it with practice. The visible tape end should turn in the tightening direction as the fastener is tightened - that's the key. About 3 tight layers of tape is enough. Don't overdo it.
