Hi everyone! I'm new to the forum and recently picked up a 96 SS. Having an issue with the cooling fans. All the fuses and relays are good and both fans run when the temp sensor in the water pump is unplugged. The passenger side fan cycles on when the A/C is turned on and cools down the motor but the drivers side fan does not turn on at all. I know the drivers side fan works cause it runs with the temp sensor unplugged. The check engine light is on and may have something to do with it. Heading to Autozone this a.m. to throw a scanner on it. Do you think the drivers side fan is bad or the sensor or both? Any help would be greatly appreciated. Thanks!!
