Hey guys I'm new to the forum. I just got a 95 not too long ago. Fixing it as I go. My Coolant fan used to work then it stopped. I disconnected the Coolant temp sensor to trouble shoot the fan. The fan turned on. I check all fuses and relays they all work. Why isn't the cooling fan turning on? Temp gauge crawls all the wat to hot. And when driving the heat on the inside is warm but cools down as I drive. I also changed the coolant temp sensor. Any help? Thanks!
Keep in mind that factory turn on/off temp settings are quite high.
  • Like
Reactions: M95ss
Of high temps? Yes ,but fans should still kick on when that close to overheating.
  • Like
Reactions: M95ss
This is a computerized car. You can make a bunch of guesses (some are expensive) or you can get a scanner with live data capability (not a cheap code reader) or free computer software and a data cable.
