Corvette fuel rail covers, yeah so I'm finally installing my first set.
I had no issue with the drivers side, but I'm stumped on the pass side.
I must be missing something here. On the pass side, no matter how I try to move the bundle of cables towards the back of the motor (big bundle by the trans dipstick) I can't get the cover back far enough to line up.
The number 8 injector wire seems to be the problem..
how do you mount these covers a lil stumped on it
Ehh Blue, there are two studs each side that screw into the intake manifold, then the covers POP onto those studs.....I have been sitting on my set for quite sometime...lol...I should probably do this, this weekend..oh well
i have a set in my trunk( nice place for them). I havent found the time to put them on either.
this may help
I had luck with a few things, bending the EGR tube a bit to give the cover more clearance,playing with the dipstick, adjusting the wiring harness along the firewall to give me an extra inch to move the wires more, and then adding a few washers under the cover mounting studs. The last adjustment raised the stud high enough to cleat the injector connectors and snap into the cover. - Hope that helps, -Dave
