1. Just purchased a purge kit, and it comes with 2 metal tubes to bend so you can direct where you want the purge to exit. Can I run -an(braided hose) instead?
2. If not can I bend the pipes by hand?
3. It's a dual purge, and there is a generic brass t-fitting that screws into the purge solenoid, can I replace with a -an t fitting, or is it brass for a reason?
R. Lastly, does the purge solenoid have to be mounted upright,or doesn't matter?
Thx
Thx
