I brought my 96 ss to mechanic to install new starter and he also cleared the PASS KEY light from the dash by reconnecting a wire that was not hooked up to the computer. The dash light is gone and the starter works great, but now my courtesy lights will not shut off unless I remove the number 35 fuse. But this also kills my power locks. I started searching for a replacement switch, but I am not sure which one I should be looking for.
Any insight is greatly appreciated.
Test your door jamb switches by pressing each one with the the key out of the he ignition, one at a time to see if the lights turn off. If thats not the problem then the green chime box might be your problem. Try to find an extra one to change it and test it out.
Sent from my Pixel 2 XL using Tapatalk
