Trying to remove timing cover and can't get the crank snout off!
The harmonic balancer came off fine - but I striped the center rod of the puller I rented and the snout didn't budge.
I've removed the center bolt and I had to get longer 7/16 bolts to mate up the puller to the snout as the ones in the kit were too short (haynes manual also suggested that). I've threaded a headless bolt into the center of the snout as a contact point for the center rod of the puller.
Any thoughts?
Thanks - Dave
Any thoughts?
Thanks - Dave
