the steam pipe that runs from one head to the other, is there a total of 1 or 2 seals per side and do what is the orientation
seal, pipe, and bolt
seal, pipe, seal and bolt
and part # if u have it if not i will look it up
Not had the thing off myself but I'd say 99% chance it's 2 per side.
Here u go
Check out this link, it looks like 2 per bolt in the picture, similar to the banjo fittings on brake lines.
http://cgi.ebay.com/ebaymotors/Head...r_Truck_Parts_Accessories&hash=item563ab7b0f6
This guy on Ebay seems to have a lot of obsolete stuff but his prices seem crazy. One 9c1 wiper arm for $40!! I just went to my local dealer and got a pair of those for $18. But this kit for $80 seems a little nuts.
Looks like he has just the seals too for $25.....
http://cgi.ebay.com/ebaymotors/Head...r_Truck_Parts_Accessories&hash=item5ad7a6df14 Check with your local dealer on that part number given above to see if you can pick them up cheaper and save the ship cost.
Instead of getting the OEM ones(which when I went to a local GM dealer they were wanting $10 a piece or so) you can get a similar part from an auto parts store as its just a metal-rubber gasket like the ones used on oil drain plugs. Just be sure to get one that fits tightly over the bolts for the best seal and torque them per FSM specs. You need 2 per side one on each side of the steam pipe fittings. - Peter
thanks guys,
