1 - 20 of 749 Posts
cwm1Book mark this and stay tuned this is going somewere peoplescwm1
The Saga of our young adventurer and his quest for power all begins with a box.
inside this box was the ultra rare CLear Image Auto
Quad1s moded to Tri-Y by CIA
well loved by there previous keeper these need some attention
now what,
Like any good Dyno tuner we need a compairo and a chart
so lets look at whats on the car now vs these new CIA Quad_TriYs.
Edelbrock 6603 shorties
calimed 1 5/8ths but actually much smaller
and on some tubes necks down to 1.25 on the bends
ports are very small.
too bad I stoped at this dimention on the heads....:(
2.085" collector on the Edlebrocks.
WTF!~ how and the heck did I make 434RWHP NA with this?
The edelbrocks have even more neck down as the hook up pipes are 2"
Were the CIA pipes stay 2.5" through out
They actually fit on the car pretty nice,
Driver
PAX
and to my suprize even fit right up to my custom exhaust that matches the Edlebrock stock cat flange setup.
from the side
Discussion Starter · #5 · (Edited)
This is were things get Dark and Ugly.
See I'm not relly happy with the secondary length or the merge collcetor size and shape.
Thes guys are just too small and short to do any real work.
Something has to change.
Well my buddy Derek.
heres some pics of DHead in action!
Or Derek Head the "Instigator" as he is Now known,
a good race and good buddy
gives me some advice
So Derek tells me .
Cortez Burned his ships on the shore.
So they would all be forced to overcome the difficulties of living in the new world.
AKA no looking back
Ok I have to log out for now.
But I'll be back with more photos and fun, soon.
Comments & Discuss!
Discussion Starter · #8 · (Edited)
So you already dyno'd the original headers prior to cutting?
I dynoed the car with the edelbrock shorties and press bent 2.5" system.
I have datalogs and back pressure info.
As well as backup dyno on a DynoJet vs the Dynapack.
I'll see your ultralite 4L60E mod and raise you an invisible driveshaft...
I gutted a broken trans case with a cuttoff wheel and sawzall.
That way I could take the trans in and out by my self to check the drive shaft clearence.
It probalby weights 7 pounds!:D
I painted it white to help amplify reflective light and increase visability.
This works great and if any local Impala members need to barrow it.
It is avaliable for loan in Cali.
Discussion Starter · #9 ·
AKA no looking back
so the saga continues
Burning ships
are now just skeletons on the shore line
Once that sawzall hits the collector
the word commitment comes to mind
cutting down the CIA collectors turn out to be a huge amount of work
The CIA headers are stout.
.080 wall thickness.
nice welds almost 100% free of slag on the ID
and very little distortion of the pipe bends
cutting the collector with a cut off wheel and a sawzall
took patience, skill and a bunch of time
trying not to not f-up the primary pipes
after about 25 hours of cutting grinding and sanding
I finally had 8 free primaries that were collector free
and then these little babies arrived
Summit Racing Part NumberFLO-C178238300
Primary Tube Diameter (in)1 7/8 in.
Collector Diameter3.000 in.
Length (in)24.500 in.
Collector TypeSlip-on
Collector MaterialSteel
Collector FinishGray painted
QuantitySold as a pair.
Significantly increase your horsepower and torque.
Flowmaster's Scavenger collectors are designed to be used as retrofits for existing headers or for a custom fabricated set.
These collectors can increase torque and horsepower significantly in certain applications
Discussion Starter · #12 ·
Way too many hours were spent at the bench.
Cut grind, expand, sand, brush, clean, over and over
eating luch over a header just comes natural at some point
Music and monster fed my veins
and my hands and head felt funny when I took my safety gear off.
hard works makes for progress
this is the preped and sectioned PAX side header
then the star of the show arrives
and is mated to the CIA tri-Yless Quad
It took a person much smarter than I to figure out how to seal the four merging pipes
at the collector
and this was the answer
Several housrs with my good buddy and his Lindey TIG welder
and more than a little polish work later and here is new creation
Yha baby it as big as a truck bed
Discussion Starter · #13 ·
Then the bad news.
Driver side did not fit with the collector.
The CIA primaries were touching my Canton Pan!!!
and all up in my custom oil lines at my distro block to the front of the car.
The Driver sade has to be 100% custom..
$^@#$ % Damm it!~
Now a full custom header is needed on the driver side.
To be continued....
Discussion Starter · #15 ·
Roger you should go to the Autox with us this upcoming March.
The B-Bodies always fair very well.
Tad,
IIRC the header on my car is pretty damn close, normal Quads to everything on the Driverside, oil filter, pan, etc.
Close enough I cant get the filter off without one of those cap type tools.
Where is this auto-x, Palm Springs?
Discussion Starter · #18 ·
Hey Tad, now that you cut up my old headers and I already have spent your money. You can go ahead and send those back:D
All of that old oil on the passenger side header is what happens when you supercharge a stock motor and get massive blow bye. Like seven cracked pistons blow byecwm4
Discussion Starter · #20 · (Edited)
Have Erica Campbell hand deliver a check 5x times what I paid for them and you got a deal.
I felt bad cutting them up.
But the sawzall went right thru..
and I felt better.
1 - 20 of 749 Posts
