I laid the parts out next to the car
Mufflers in there place parralle to there place in the car
X parralle to it's place in the car
blank piece of pipe to fill in for the 24" collector
slide it under the car with painters tape for welds
offstands set the height
right out of the box this stuff fits ok
but since my car is so low
the driveshaft area really REALLY needs to tuck to clear 3"
this is not the final layout this is right out of the box
notice the cant on the mufflers
later I squared things up
the collector needs to clear the x-member
and the x-member needed to go up to make room for the exhaust pipes and collector
the post x-pipe tubes need too tuck up against the drive shaft
with the X right at the driveshaft loop
the lay out is simple ... but I spent a bunch of time tweeking it to my wants
set the x up to the loop with an offstand
set the mufflers in there intended home with offstands
connect point A to point B
The final layout in painters tape looks like this
