I have LT1 355ci with aluminum (ported with a 3 angle valve job). I had comp cam make me a cam for how the car is used (Daily day driven with 3.73s and 2k stall converter). They grind me 214/224 .530 .530 w/1.5 RR lsa 114, how would that cam perform, what kind of power would i be looking at out of that cam?????
Super Moderator
Shouldn't you be telling us about your custom spec cam, not the other way around?
214/224 .530/.530 w/1.5 RR lsa 114............ How much more info is needed????
.......They grind me 214/224 .530 .530 w/1.5 RR lsa 114, how would that cam perform, what kind of power would i be looking at out of that cam?????
Smooth idle, good gas mileage, good throttle response through the RPM range.....and depending on how well the heads perform.....I'd give you (and this is a SWAG) about 300 HP @ 5800 RPMs and 320 TQ at 3500 RPMs......at the wheels.
KW
KW
That sounds pretty good!!! I kinda wanted a little more, but i guess its a little too late now......cwm6
