After carefully removing,and unplugging the stock bagged wheel,instead of buying a mod kit you'll have the red light in the dash cluster on, it's annoying,With the wheel off you'll be able to remove your dash face ,behind that plastic panel, you'll be able to acsess the few screws that hold your gauge cluster in,remove the screws and gently pull the cluster out,remember to unclip the gear indicator cable,it's held onto the lower part of the coloumn,it slides right off. Before doing this remember where the light is located in your cluster,then while it's out just remove the bulb.I went the next step and used some Meguiars plastic polish to clean the lense inside and out,tested and wiped off each and every bulb in the cluster,and with my girlfriend's fine make-up brush dusted the gauge face around all of the pointers,and carefully wiped it down with a small soft damp cloth,after reinstalling everything my dash was so much more clear and bright,with the red light gone. Good luck!
