can somebody give me a step by step on how to take the upper part of my dash out of my 96 chevy impala ss.
mmm ive tried this way only to end up tugging and pulling when lifting the upper dash was more convenient but to each his own.The upper dash assembly does not have to come out to remove or install a stock cluster. Just pull the gauge cluster bezel and the lower dash assembly off and there is more than enough room to pull it out and put it back. If you are upgrading to the Z28 cluster you will probably have to pull the upper dash off though. And to pull it off there is a series of screws along the edge of it and then just work it off gently so you don't break anything under the dash. - Peter
