Will the radio lock up on thr InOP if you continue to try after your 8 and continue while having three tries. Is there a set number to the amount of times you can wait an hour and try agian.
T
That lock feature is the big useless PITA! I had the dealer turn my theft feature off. I think that needs to be reset if you remove power from radio... that is... if you disconnect the battery, or it dies.
