what' up guys i got a CPT LV 3 tranny and i was wondering im about to do a tranny flush and filter change i was wondering if dexron 6 ok to add into the tranny? Thanks
so i'm guessing from what i read that's a no go on the dex 6 and go with regular dex 3 am i correct thanks for the link, i just wanna make sure
Some Dexron 6 info from Gm
http://www.sandyblogs.com/techlink/2009/05/
And from the article
IMPORTANT: As with previous upgrades, DEXRON-VI fluids are designed to be backward compatible with earlier transmission hardware. But more important, earlier type fluids are NOT FORWARD COMPATIBLE with transmissions that were designed to use DEXRON-VI.
DEXRON-VI can be used in any proportion in past model vehicles equipped with an automatic transmission, in place of DEXRON-III (for instance, topping off the fluid in the event of a repair or fluid change). DEXRON-VI is also compatible with any former version of DEXRON for use in automatic transmissions.
