This sticky contains links to all of the great posts made over the years that can help you fix your B-body.
GENERAL HELP
Impala SS Forum Tech Tips. New submissions are always welcome!
Lots of good F-body LT1 information, much is useful on the B-body LT1.
F-body LT1 diagnostics. VERY useful.
how to rebuild your LT1
Fastener tightening specs
Buick Roadmaster climate controls allow you to do some engine diagnostics.
Differences between LT1 and LT4?
Didn't someone post the Haynes manual online? Where can I find it?
What can I use a vacuum gauge for?
DCM? BBB? 1LE? What are all these acronyms and abbreviations?
SAFETY ISSUES / NEW OWNER CONCERNS: (things you should check immediately)
'94 owners: Aux Battery Post should be made out of brass and not zinc. Can cause fires! Also causes weird drivability problems.
AC drain elbow gone, causing cabin water leak
AIR Pump TSB
Coolant line plastic fittings (T and restrictor) can break with age.
Exhaust manifold bolts are prone to breaking. Also, fix your RH exhaust manifold by cutting the ribs
NO START
Good diagnostic thread
TROUBLE CODES
OBD1
OBD2
POOR GAS MILEAGE
good info here.
more info.
MISFIRE / RUN ROUGH
systematic diagnosis of misfire/backfiring.
code 16 / 36 / P1371 misfire codes - could be the opti or opti harness?
IGNITION
coil: how to upgrade a '94-95 to a '96 coil. Pinouts
coil wire often corrodes. It's on the front driver's side of the engine.
Ignition Control Module (ICM) - if the car doesn't start on dewy mornings or just up and dies while driving, it could be the ICM.
plugs
wires
wire routing
plug wire heat shields - where do they go?
OPTISPARK DISTRIBUTOR
Watch this video FIRST before trying to diagnose your ignition system.
here's a written procedure based on the video thanks to user "juniorwatson"
is the '94 B-body opti different from the '95-96 units? no.
optispark ("opti") shopping advice
optispark diagram for DIYers.
optispark diagram for DIYers part 2
helpful optispark diagnosis thread
rebuild or replace?
How to Remove/Install your optispark
How to Remove/Install your optispark #2
How to Remove/Install just the cap and rotor
opti maintenance, especially if you are replacing the water pump
optispark alternatives
vent harness anatomy
VIDEO: How to replace the seals in the timing cover that drive the opti and water pump.
Can I flush out my opti? Would it work better afterwards?
Do I need the o-rings on the opti shaft? What size are they?
FUEL
fuel pressure checks
bad / leaky injectors
how to tell if your fuel pump is bad
how to drop your gas tank and swap the fuel pump
fuel tank drop #2.
FUEL LINES
Steel fittings on the end of the factory nylon lines rusted out and need to be replaced.
FUEL GAUGE / GAS GAUGE / GAS HAND
how to refurb and recalibrate the sending unit
fuel gauge calibrator if you're lazy or don't want to drop the tank.
AIR pump (Air Injection Reaction)
Check valves known to go bad and leak fumes back in
GM's TSB
IDLE SPEED
High:52mm throttle body / throttle cables / IAC?
Low: low idle speed + misfire, good systematic walk-through.
EGR (Exhaust Gas Recirculation)
"What is a EGR?" - everything you need to know about EGR.
EGR FAQ
poor drivability caused by EGR
how to test for bad EGR
GENERAL DRIVABILITY
Try Motorvac. List of shops.
split BLM's with aftermarket throttle body.
SENSORS
bad Throttle Position Sensor (TPS)?
bad Mass AirFlow Sensor (MAF)?
bad Crankshaft Position Sensor (CPS)? (only on '96 engines)
where's the coolant temp sensor?
Oil level sensor on driver's side of oil pan causes low oil light.
GENERAL HELP
AIR Pump TSB
NO START
TROUBLE CODES
OBD1
OBD2
POOR GAS MILEAGE
good info here.
more info.
MISFIRE / RUN ROUGH
IGNITION
plugs
wires
wire routing
rebuild or replace?
FUEL
fuel tank drop #2.
FUEL LINES
GM's TSB
IDLE SPEED
EGR FAQ
GENERAL DRIVABILITY
SENSORS
