1 - 20 of 61 Posts
My digital cluster in my 94 caprice works when the headlight switch is off but when i turn the headlight switch on it goes out anybody ever had that problem or is it my wiring going bad?
Probably the headlight switch. It changes circuits when engaged.
If this is a 9c1, look for the "stealth" light switch. under the radio. Same behavior on my 1A2.
yeah sounds like "stealth" switch but wires must be crossed...won't do much good turning your digital dash off with your headlights oncwm3
Discussion Starter · #15 ·
yeah i have the steath switch when i hit it, it does nothing when the lights are on but it turns the digi dash off when the lights are off
My dash lights go out when I turn on my lights but you can still see the digital gauges. I think its a switch as the dash lights were flickering before. My car is a 95 SS with twilight sentinal.
1 - 20 of 61 Posts
