+1, maybe the shops blunder involves the pcv hose? You could try 1 grade thicker oil, but thats a band-aid for excessive blow-by, since its caused by bad rings. You could also check to see that the pcv has vacuum.Either the PCV/vent hoses are clogged, or you have excessive blow-by.
