So sick of putting money into this caprice....just done the front end...800 dollars. Now the Damn thing won't stay running. Getting moister in there I think....pisses me off...put so much money on it that I don't want to junk or...sure thinking bout it....
Is the vacuum harness working? Seems like the first place to look for moisture in the Opti, if that is really the problem. Fuel pressure? When did you last change the fuel filter?
2013 I think I changed the fuel filter....it fires up for a few minutes and then it won't start up again.....hope its not the opti...lot of money ...and no one wants to work on it....sucks
Again, is the vacuum harness working? How old are the wires? The seals on the opti may be shot. Do not replace the entire Opti. Use an MSD cap & rotor set and be sure the vacuum harness is working.
If moisture got in the opti, the whole thing definitely needs to be replaced.
Send new opti to me if you want it blue printed and assembled and sealed correctly.
[email protected]
Nab
