1 - 20 of 23 Posts
If anyone has there dash removed, there is a
black vacuum line that runs beside the heater
core box, its the only vacuum line beside the
heatercore box coming out of the firewall in this location, if someone
could tell me where this line runs it would be a
big help.
big help.
it's a drain so when your heater core goes out, the coolant goes outside of the car instead of inside the car. However, even when the heatercore does go out, coolant still ends up inside the car.
it is sucking in a lot of air like a vacuum line, are you sure, is so where do I connect this too? thanks
im not sure about a sucking noise but, you have that black plastic box covering your heater core rite? and that black box has a peice coming off that looks like a hose would hook up to it but it just goes into a hole in your fire wall then thats it rite?
Discussion Starter · #9 ·
I'm going to go check and get a pic up, please check back to help me out layer today.
Discussion Starter · #13 ·
man I didn't feel like pulling the dash, I can see where the Orange line runs now, hopefully I can find this without removing dash
okay, I thought you were talking about somthing els. as far as removing your top dash, it isn't hard at all. once you pull the 6 or 7 7mm bolts you have to remove your 2 a pillars than the top of your dash will slid rite out.
Discussion Starter · #15 ·
I see where the Orange vacuum pine runs, yet I see no big nipple for the black wire.
anyone? I removed dash and looked everywhere visible and can't find no where this would go.
Discussion Starter · #18 ·
or if someone can look under there dash and let me know if it runs up toward the airbag or turns toward the hvac controls.
Persistant are we :). I hope the picture below helps you. Sorry it is a little blurry but the picture was much bigger and I had to crop it.
Let me know if you need anything else.
TOM B
Discussion Starter · #20 ·
yes it runs right under airbag, how do I remove the airbag without, well you know.
1 - 20 of 23 Posts
