convert the stock TBI air cleaner box to the round traditional style? I would really like to do this so I can get the TB riser plate and shroud for more air flow.
Thanks,
Chris
R
You're in luck. The neck on the stock TB is the same as that of the good ol' 4 barrel carbs of days gone by. The only thing you will have to change is to take out the two studs that hold the air box down and replace them with a single center stud, which the TB already has a threaded hole for. Then you can add any "old style" air cleaner assembly you'd like. HTH. Rahn
