Ive replaced idler,tierods,centerlink.
Ive now bought Energy Suspension end links,sway bar bushings,front and rear control arm kits/bushings.
What else should I have done at the same time?
Ball joints? what size? part numer?
If I end up buying BMR rear LCA's will these bushings work?
By the way,after install of parts listed in firt line,it tighten up a little but still have a little wobble/play in steering wheel when hitting bumps and lots of wandering and a uneasy feel to the handleing.
I'd do the ball joints as well if you are going to be in there. Usually if I have to do a job like that I'll just go in and replace anything that can wear out just because I hate taking things apart more than I need to. Are you sure your shocks are still okay? I see you are running 20" rims which can also tend to wear suspension parts out a little faster too. There should be a procedure in the factory service manual for checking/adjusting the steering box. Just be careful as it is easy to mess it up. How is the rag joint on the steering shaft?
Thanks guys. Just what I wanted to hear.
Appreciate it!
Oh ya, one more thing. If Im going to evenyually buy BMR rear LCA's, will these Energy Suspension bushings work or will I be replacing those again with BMR ones?
