I decided to fix my door detent roller. I bought one for a truck that has the same major diameter but the lower shaft is too big. I ground it to 5/16 of an inch up to 1 1/16 inch from the bottom, and threaded it. It was pretty simple, and the die got rid of the grind marks. It will fit in place of the OEM part after removal. If you go a little too far up the shaft, you can put a washer under it to fine tune the position.
Pic of original, and modified part below.
Good Morning sir,
I am having the issue with my doors and finding a OEM replacement is a nightmare.
Nice find, thanks a million for the info
