i have a 95ss when i press the unlock button the front door on the driver side unlocks some times and sometime not changed battery it still does this and when it gets dark the auto lights come on but just the headlights not interior or tale lights dont know what to ck
Do your lights work properly with the twilight sentinel off? Did these symptoms all occur at once, or do you have a couple of problems that you have not addressed?
The locks could be the keyless entry module. or the DS lock switch. I would try the module first. The switches are easy to break when trying to remove them. You could use a window switch to check the operation.
The lights could be your twilight sentinel module or the switch.
?? His remote locks and Twilight Sentinel are not working, but the manual control for the lights does. :confused:
When you turn the TS off, the car reverts back to manual. If the TS is malfunctioning, the lights will then work porperly.
