Does the power window regulator operate to it’s stopped window up closed position by sensing when the resistance is felt to stop the motor, or is it when it reaches a certain position of where window up closed should be ?
I’ve got a wind whistle at higher speeds that is annoying and I’ve noticed the glass itself is loose in the runner it mounts to.
Should I have the window reset by an auto glass repair shop, or is it due to the molding at the top of the window ?
I’ve tried using clear tubing inserted into the slot of the molding along the top to put pressure against the window while closed, but this has failed to stop the air whistle while driving.
Any and all advice is greatly appreciated.
