Hello SSers
today I rolled down my window using the auto feature and once the window reched down the switch did not stop, and the window does not roll up, the motor makes noise when pressed but the window is still down, I removed the panel and descovered that the window is freely moves up and down all the way by hand, it is a bad motor or smth else is broken?
can I replace the motor itself or need to take out the whole thing?
any once experienced this before?
enjooooy driving the monsters
I think the gear on the motor is stripped or loose on the shaft. A motor should fix it.
