Yes exactly , dial it by hand .
Once you figure out the where and way and how much , you can approach the builder with solid info.
While not often , new yokes can be out.
If it is the shaft and you are stuck with it , there are things you can do if it is out on the ends.
There are hard to locate selective thickness clips. You can also grind- shim 1350 clips .
Yeah you should never have to to that but sometimes " the cards you are dealt "
Problem is if it was balanced with run out , that goes for a crap.
" should of "
I had a 5" Silverado SS shaft shortened locally for my wagon. They made a right mess out of it.
Another shop had lots to say about the first shop but when they got completely different run out numbers than me I took it home and pulled the weights + fudged the clips.
Worked fine to 110 mph with 4.56
It was shelved for a MW carbon and billet yokes when I did the drivetrain swap.
A word on yokes , you will find many of the driveshaft company's high end option is MH.
Says something when someone is selling a competitors product.
Mark Williams Enterprises is an industry leading manufacturer of drag race axles, drive shafts, brakes, modular rears, rear end housings, thirdmembers, and chassis components.
www.markwilliams.com
