L
I bagged my caprice and it looks good. It tucks 20 just about 1/2 of rim inside the fender well. I would like to install drop spindles to lay my frame on the ground. Air Ride Technoligies doesn't recommend it but I dont know if its possible. the only problem I would see is how hight the car would lift. I think it would just barely clear the wheel well. . Has anyone every done this?
W
nice double post :D
belltech drop spindles will give you 2" of drop. So if your frame is less than 2" from the ground you can lay it out all the way. But remember, this will take away 2 " of lift.
I can clear my 20's no problem. I have drop spindles. If i have it maxed out, i have about 6-8" of clearance between the top of the tire and the fender
L
Do you have any pics of your car laid out and up all the way? I have a 91 sedan. Same as your wagon. So they should be the same. What size bags do you have up front? I have 2500s. 6" of clearance above the tire when up is hellatious
