If I swap from rear drum to rear disc brakes, how does this affect the wheels location? In or out?
It depends on the method used for conversion.
If you just compare the thickness of a brake drum with the thickness of a brake rotor, the difference is about 0.125" (1/8") per side--the brake rotor hat being thicker than the drum by that amount. This is the difference you will see using WRDC.
If conversion is accomplished with a spacer or longer axle shaft (to use OE B-body rotor/caliper package), the difference is closer to 1/2" more per side overall.
If you were to fit a sedan axle into the wagon chassis--which I do not recommend--both versions of the sedan axle assembly are considerably narrower than the wagon--1642.5mm vs 1598mm (Impala width) or 1566mm--23.75mm or nearly an inch shorter per side for the Impala housing, and another 16mm (5/8") per side for the narrowest housing.
