1 - 9 of 9 Posts
Considering going with a less expensive route on the nitrous and using the Holley/NOS kit #05176TBNOS instead of a dual stage or direct port for now. I already have the TB, just need to get the nitrous side. I asked Holley why the kit is only rated at 135-150 HP, and they said that it was due to the stock LT1 fuel injectors. I kinda knew that, but wanted to verify that the TB was capable of a bigger shot, and wouldn't have any disperse pattern problem.
My problem is how do I find out what size injectors I will need to handle a 200-300 single dry shot on top of my 383. Wondering if 42s will suffice, or if I should stick with the 50s I had with the stroker/blower setup I was running? A gradual aproach in upping the shot will occur, I just want to prepare for the max, without sacraficing idle/driving caracteristics with the large injectors. If anyone can point me in the write direction it would be great. Thank you,
Mav
try this guy: http://www.dynotunenitrous.com
:eek: damn....what fuel pressure will you have to run with the nitrous on? you sure the injectors will handle that much pressure?? imagine a couple of injectors locked close with that much nitrous going in the engine..... BOOM!!!
Thanks for the link!
Been doing some research, but I still don't know. There are a few guys in Camaro land that are doing this just fine, but it appears they are setup for even bigger injectors than I have. Fuel pressure would have to be over 80psi, and an a fpr/fmu setup will take care of this. I just need to know what injectors to go with.
Mav
Be careful with the pressure... The higher you set the pressure, the LESS flow you will get.. With N20, it's the amount of fuel that is important... A lot more than the pressure.
For example...
A High pressure Walbro 255 can flow 244lph @ 40psi, but only 180lph @ 80psi.
Get a good fuel pump if you plan on that much pressure.
BTW, According to Kenne Bell, 42lb injectors can support up to 672hp at 43psi.
You have mail.
A neat little thing I made for when I was planning my N2O system.
It worked for me pretty well.
1 - 9 of 9 Posts
