Don't think it was CAFE, think it was EPA in this case, mandating that there be different EGR Valves for what the EPA considers sufficiently different applications.... I think if the GM engineers felt a "common" EGR part would suffice for both platforms, B&F, then that part would have been used.
Like any manufacturer they would not spend $.02 on anything if it was needed to reduce CAFE #'s amongst their car platforms.
I suspect it was emission function was the primary reason the 2 are different.
B bodys were the comfort/cruise platform and F bodys more a performance model with different exhaust systems.
With that said, IDK part # for the Vette EGR ... but suspect it is also different for the LT1 years.
That said, I basically agree here.
That the EPA may occasionally mandate that there must be two (or even 3?) different EGR Valves, does not necessarily indicate or imply that the OE B-car LT1 4L60E EGR Valve is BETTER for those keeping the restrictive OE muffs and tailpipes than the F-car LT1 T56 EGR Valve.
More research would be helpful ...
