Seems better to diagnose the code problem(s) to find out what's going on. Pretty much four choices: bad solenoid, bad EGR valve, cracked wiring/plug at the solenoid, and/or leaking vacuum lines. See DTC section of shop manual.
Which solenoid are you referring too? I have disconnected pretty much anything that goes to the EGR and plugged it up, I will attach a picture on how I have it set up. It could be that one of them slipped off or cracked open so im going to check on that. I did notice my throttle body elbow has a crack I have a picture attached, that might also cause the issue.Seems better to diagnose the code problem(s) to find out what's going on. Pretty much four choices: bad solenoid, bad EGR valve, cracked wiring/plug at the solenoid, and/or leaking vacuum lines. See DTC section of shop manual.
What will happen if i just put the block off plate on there without tuning it out from the car? Will it just have poor fuel mileage or something else will happen?Deleting EGR requires PCM to tune it out
A functioning EGR system has no performance loss but will cause issues if its not fixed
so you have 2 choices, fix it or tune it out and remove it entirely using a block off plate.
IDK about what emission inspection you have...many states do require emission equipment be left on car regardless of it needing emission testing.
Without disabling the EGR function in the pcm, the pcm will keep trying to use the EGR Valve that is missing - it will not 'learn' or 'determine' that the EGR Valve has been deleted / blocked off.What will happen if i just put the block off plate on there without tuning it out from the car?
Okay I understand now. I just need to find somebody who can tune an obd2 lt1Without disabling the EGR function in the pcm, the pcm will keep trying to use the EGR Valve that is missing - it will not 'learn' or 'determine' that the EGR Valve has been deleted / blocked off. Only reason why I can't tell you exactly what would happen is because I've never done it myself. When I deleted the EGR Valve'n'stuff, I also disabled it in the pcm. (I only tune OBD1 LT1s at this time.) But even after you fix the crack in your throttle body elbow, you will likely experience drivability symptoms whenever the pcm tries and fails to use the EGR Valve that it still thinks is there - until you reprogram it.
Then the light can't ever warn you about other problems.Im leaning towards just buying the back plate and leaving the check engine light on,
