R
Is there a reason why my cooling fans should be on immeditely after starting my car? Yes, even when it is cold outside.
R
Yes. But the read on that says it's because of my mass airflow being bad.
F
when check engine is on, both fans will turn on... :D
V
In addition, it will apply full pressure to the trans, so it will shift really hard even at part throttle. Fix it ASAP.
