i need the instruction i found a kit that i've looking , for quite some time with no instructions a copy of the original would do as well any help would be greatly appreciate thanks
I bought one from a member here, he is no longer making them,this was his schematic.
http://www.lt1engine.com/tech/electric-water-pump-wiring/
I did not post it but I found it on this web site
http://ltxtech.com/forums/showthread.php?628-Electric-water-pump-wiring-quot-warning-system-quot
a side from the temp switch all you need is two long wires, two LEDs and a relay to trigger the red led (cost < $20 ; the buzzer is an over kill) the red led and buzzer will trigger when your engine is over heating but I"m sure you will spot the temp gauge before the red led and buzzer go off.
the main point to the kit is the green LED: green LED "ON" = your electric water pum is getting the 12V it needs to operate
