Whats lube should I use for my Emergency Brake Lever mechanisms that are behind the rubber boots? Is my Sylglide Hi Temp what people would recommend? any better products recommended? Thanks.
A more viscous grease that is water-resistant would be more appropriate....this is an area that doesn't see a great deal of temperature elevation, and it's more important to use a product that ensures the parts remain lubricated and able to repel moisture intrusion. I don't think this is the product you should use.
Currently, when I build a brake kit, I use Pastelub - a moly-based product that's very "sticky". The original "blue goo" lube in the GM/PBR rebuild kit was good too, but it's never been identified as to source or spec, and only came with the rebuild kit, which, for the most part, no longer exists, unless someone is willing to pay a very high price for the kit (GM 18021516).
