Has anyone used the energy suspension rear spring isolator.? Also can I use this isolator on the top as well as on the bottom of the rear spring? I'm replacing the rear springs with 9c1 springs and purchased two sets of these isolators? Just curious how well they work. :confused:
yes and yes
Grease the snot out of them with a good heavy grease (I used white lithium grease) or they WILL squeak!
They seem to hold up a little better than stock isolators (I swap rear springs a lot), but that's about it. No performance gain over stock.
Like I said, grease the snot out of them. If it has a surface, grease it :D
