Hello,im installing a tubular crossmember purchased from Clear Image and i also have a energy suspension transmission mount that came with it,being that this mount now goes on a different location on transmission (for those that are not familiar with the 4l60e,it has two mounting locations for the mount),well with the tubular crossmember the mount is relocated closest to the transmission pan...with that being said can anyone help me as far as the spacers that came off the old mount,how many have you used when doing this installment? The energy suspension mount comes with one spacer and its mandatory as far as the instruction say,then im left with the two orginals that came of old mount.also the new location sits lower than old location, dont want to mess up pinion angle,can anyone help as far as how many shims to use or what you did when you installed yours,thanks
