I'm trying to piece my car back together. I need some engine bay shots from a stock type lt1. I need a good pic of the wire and hose routing on the passenger and driver side fender/exhaust manifold area. More specifically I need to see how the power steering and AC hoses route and the fan and AC wiring. Thanks
The harness that goes on the pass side valve cover goes down the front of the engine behind the alternator, hooks up to ac clutch and high pressure sensor on the a/c hard line.
AC hard line has a sort of u-bend in it which goes under the ps reservoir if memory serves. PS hard lines go over the top of the a/c compressor.
