1 - 20 of 26 Posts
Does anyone have advice on how to clean the LT1 engine in a Impala without destroying the Optispark in the process? I like to degrease my engine compartment from time to time but now I’m afraid to because of potential damage to the Optispark. Any advice is appreciated.
I’m replacing my Optispark right now due to contamination inside the cap and rotor compartment. This design is ridiculous, so I just let road tar and engine grease build up forever?
Banned
you comments are very strange to me road tar and engine grease ..
never seen that on my vehicles . dust/pollen/snow ya !
It just takes elbow grease...not a hose
spray degreasers, rags. Then spray protectant on plastic parts and wax on painted fender wells
Time consuming...like anything else it just take work.
Thank you! Sounds like good solid advice. I live in Southern California and the roads are covered with oil droppings and grease from the heat.
And with 133,000 miles on it there are slight oil leaks here and there from the engine. But I will take your advice from now on.
Take some time now, while it is off, to completely seal the cap to the body with silicone. Also locktite the rotor screws. The seal that comes on the opti stock is a joke. A bead of silicone will go a long way.
I live in SoCal also...and have the same mileage as you do. I have however kept the engine clean since new even when the car was a DD so for me it is easier to keep the engine bay clean vs doing it for the 1st time at 133k mi
get yourself some latex mechanic gloves, old tooth brush, spray bottle of simple green and some old towels to use as rags
You would be surprised how just wiping down stuff with rags only cleans up. Especially on suspension parts and under the motor where some oil/grease is
Simple Green works well for a degreaser but does dull paint and aluminum so use prudently
spray cleaners for vinyl dash & rubber parts works well on all the rubber stuff
A little cleanser on a tooth brush with light water on things like the coolant and windshield reservoirs really bring back the original look. Coolant tank does stay yellowish though. Then use some protectant spray sold in various brands at auto part stores
Yeah all this takes time but end results are worth it. Then just periodically maintain it with wipe downs before road and life crud get to much
Was watching Chasing Classic cars and the old guy was using WD40 to clean all the wiring on an antique.
I tried it and dang if it doesn't work great on just about everything.:cool:
Banned
the use of solvents can be dangerous on the plastic/rubber/wiring etc.... If I do have to clean up an oil/grease mess I use low odor mineral spirits .. never ever use any brake cleaners as these have acetone , a solvent that will destroy these materials .. carb cleaner NO....
It's not rocket science.
Cover the alt and the battery with bags. Spray the engine and engine bay lightly with water and citrus based engine degreaser. Let it sit while you scrub the really dirty areas. Rinse by lightly spraying with water. Repeat if necessary. Start engine when done to help dry it. I was never a fan of spraying water on a hot motor. YMMV.
You're not gonna kill your opti. Just don't spray it directly with full force from the hose. It's not like the thing isn't in a prime position to get wet every single time you drive in the rain. Unless you've got other issue with your opti, which you would already know about.
Hi, 4doorss had the 2nd link that had the link that was the original method.
Engine Cleaning/Detailing
seems safe enough and that's what i do.
-ALF out..
The WD stands for Water Displacement. The main ingredient in WD40 is fish oil.
I've always sprayed copious amounts of Simple Green on a cold engine and the rinsed with a open water hose.
Never caused an opti failure....... cwm1
KW
IMHO...if one does chose to run open water on the engine...not something I endorse...use air compressor or leaf blower after
The electrical connections using "weather pac" are pretty good at keeping out moisture (especially if previously treated with dialectic grease) but the wire to plug orifice is not as water tight even though there is a small rubber sleeve on that part of the wire inside the connector..
While water exposure can sometimes cause immediate issues (no start or miss) the engine can initially run fine but the moisture that did get inside connectors starts corrosion which later can make that circuit stop functioning or become intermittent...and then chasing wtf wire is causing the issue can be a long chase given the # of electrical connections under hood
Yeah people have gotten away with it as mentioned...rags, elbow grease, prudent use of cleaners and protectants is what I have chosen. YMMV
If you're so worried about getting the engine wet I'm not sure why you would recommend forcefully pushing said water in and around various electrical connections with high pressure air. That's literally the worst thing you can do.
Just run the engine until it's dry. It doesn't take long, especially with the hood closed.
Any water that does get in the plug boots will be dried by the heat of the engine and the exhaust manifolds or headers as well. Not sure how you would even get water in there...rinsing from the top down like you're supposed to.
Again, it's not rocket science. Everyone's got their own opinions on how to do it best. Just remember a little common sense goes a long way.
Banned
washing these engines with opti mounted as I said before is not good..water or any liquid will get into the distributor . perhaps covering the opti with plastic sheet with the venting hoses and the electrical connector/plug wires removed should work ..BUT NOT an easy job to cover the opti perfectly from any contamination ..the EGR is also a component that does not like any water , as this design is not to have water on it .so wrap the EGR up with plastic ..
water should not cause corrosion on electrical connectors but chemicals will,, like ACID type cleaners ..
I had access to steamer washer , this I used to clean electrical devices with NO cleaners just plain water and high water steam temps .. worked great but I had to seal up portions of the components from the steam/water... the cleaning did work great and it did dry quickly as it was about 200F on the blow down of the cleaning process . I also used this to clean up circuit boards before they were to be repaired .. located in a very dirty environment ..
How? A proper functioning opti will hold a vacuum. That means it's air and water tight.
Just don't shoot the damn thing directly with the hose if you're paranoid about it.
If you think your opti doesn't get wet with normal use live in a fantasy world lol
If you had a lot of stuff in there, I'd be sure to check that the Opti vent harness is working as it should. That may be part of the problem. The design of the "sealed" Opti REQUIRES that it is vented with clean air to to not build up the junk inside. If not, you can kill a normal working Opti in a hurry.
Lots of stories of these normal working Opti's lasting for 100k ++ miles. Mine has and driven thru many nasty rain storms and some long road trips for many years without a hiccup. the location orf the Opti, although not ideal, has never seemed to pose too many concerns to me. Again, assuming it is sealed and has a working vent harness.
1 - 20 of 26 Posts
