Engine cranking problem!
656 views 2 replies 2 participants last post by  mistereastlos
#1 ·
After doing the throttle body bypass, I tried to start the engine and it cranks but doesnt start. I ended up taking off the throttle body bypass and reconnected hose back to it's original location. On doing this I some how broke the evap purge solenoid hard line in three parts. What I did is I connected some gas hoses to the hard plastic line and made it fit back to the throttle body and evap solenoid. Now my engine cranks but stops cranking after 2 seconds. Why is it doing this? The oil pressure light and battery light on. I replaced the oil pressure sender and new battery. Lights still on. I cant get any codes from the obd2 reader, because the battery was disconnected for a week. Can anyone help me please, thank you
#2 ·
