Ok here's the deal. I've had my 95 9c1 for about 7mths now and consider myself the best owner the darn car has seen thus far..1 problem is after a while of driving my CEL comes on. I noticed the light is only on when my fans are on. Yes both fans are on. Sometimes when I turn my key to the on position I can hear the a/c compressor clutch engage even when I do not have the climate control switch on. I unplugged the harness to the a/c compressor and took a drive. Engine light remained off popped the hood and just 1 fan was on as it should be...
My a/c compressor is BAD as far as it leaks freon from the clutch while in use.
Is this my problem or should I look elsewhere??
