Is it possible to do this or does it only work on the 93 and older cars? My buddy put one on his 93 fleetwood that he pulled off an old cop car but i know the 93 is a different motor.
Some LT1's came with this setup and think this is the HD Cooling option. This article has some info in there about this Clutch driven fan.
http://garage.grumpysperformance.com/index.php?threads/lt1-cooling-info.2538/
There are some parts/brackets/belts/etc you would need to pickup if this was something you were serious about. Most usually convert from this to electrical so you may have luck finding parts. Finding a donor that you remove yourself would be ideal since you could note how it installs and grab all you need.
