Hi guys,
my 1996 impala ss 85,000 original miles starts after 3 times. The third start the engine turns on then it shuts down. When the engine starts the engine seems low on power or low idle I guess and then becomes normal.
Also, I'm planning on either buying launch crp ob2 scanner or Innova 3160g Pro scanner. Will either work for the 96 Impala? Also can I post the freeze frame and other data on this forum so you can guys can help me if something is wrong?
Sorry for the paragraph.
Thanks,
Fatin
Search on here or online how to perform a fuel pressure test for your car. You've received no feedback on the scanner(s) since you first asked about it or them 4 months ago. It will be best to confirm application with the manufacturer, or at least the vendor.
