I am new to the post and maybe this has been covered before. I have a 94 caprice with a 4.6? 305 I presume. I also have a 94 caprice cop car. I would like to put the 350 into to caprice with the 305. What do I have to swap with the change;computer, electrical, etc. Thanks
Yes it has been covered.........
you have a 4.3l (what is known here as L99) which is a 265 cid, as long as you have 94 and up cars, then the swap is not that difficult.
The "350" car is an LT1 IF it is 94-96
Yes swap the motor and ECM
Do a search, and you will find more info on this.
V
Do a LOT of reading before you ever turn the first bolt.
You can use the same PCM (computer), but it has to be reprogrammed.
Next thing ya know someone will try putting an LT1 in a Jag......................
V
Some morons will try almost anything...
Why would he use the same PCM, if he has a good LT1 PCM??
see my sig
Frankly though seeing as you got the displacement in litres and cubic inches wrong I am guessing a motor swap is beyond your immediate abilities.
