1 - 20 of 20 Posts
J
I have a 91 with the 5.0. It has 247k on it. I want to put a 350 in it this summer when I have time for the swap. What is the range of years i shoould look for? I am pretty sure that i can use a 91 to 93 350, but will i be able to use a newer one? I do want to do some mild mods, (cam headers..etc...). I just think it would be better to start with a the highest output motor i can. Any thoughts are appreciated
T
I think most of your replies would be to save up for the 94-96 body style. Although i haven't tried this, there's many people who have-and with plenty headache. From my understanding it's not a direct drop in. You need to fab some of the body to get it to fit. Most people would reccomend an aftermarket crate engine that just drops in. 94-96 were the years of the 350 LT1 in the b-body. 91-93 were the years of the 350 L05. I too would want to do this, but most people told me i'm better off buying a b-body prefitted with it.
D
You can use a block from an 87 and up since it usues the single piece rear seal.With the 87 and up you could use your drivetrain parts and stay with a hydraulic roller cam.The TBI/intake would be the first limiting factor when you change over to a 350.
J
Since the engine will not cost me more than $1k, I'm not too worried about the 94-96. The car still runs great, I pretty much just want to be prepared. Thanks so far for replies. I know that the LT1 is not a direct bolt in. That would require body mods, so not going the LT1 route. Just straight 350, with some mild mods...cam, headers, etc...
L
just my two cents:
a TPI engine from 89 - 92 F-Bodies would nearly be a direct bolt-in ;) with aftermarket wiring harness and chip for the ECM its much easier than getting a LT1 running
i have a 89 TPI in my 91 Caprice:
(since 89 uses a MAF sensor, i had to convert to electric fans because of the air duct, 90-92 TPIs are MAP so you could use a K&N filter directly at the throttle body, so you could keep your fan of the caprice)
D
You actually need a TPI ECM that matches the system(SD or MAF)
LittleNo,
WHich fuel pump did you use
L
sure, 1227165 for MAF, 1227730 for SD (MAP) - but for both you can make your custom chips for the swap and for both a painless wiring harness is available
i use a fuel pump of a 91 TPI camaro - fits exactly into the in-tank unit of the caprice
D
agreed..You dont need to burn a PROM if your cam/timing curve is within the parameters.With the stock TPI you cant do much anyway.
J
What kind of power does the TPI motor make stock? Would a 'vette motor of the same years work also?
Do not get hung up on "Vette" parts all it will result in is paying way too much and not getting the performance you want. The Vette is lighter and therefore the cams in pareticular speced for it are not always going to work well in a b-body and were usually the same as the f-body anyway.
To put things in perspective though the very best TPI heads flow 15% LESS than the stock LT1 b-body heads. The lowend torque will be nice though with a TPI.
L
you need - all F- and Y-Bodies 89-up have VATS, without a custom chip the ECM just does nothing - and you should change some things like the TCC lockup speeds, since a B-Body weighs much more than a F-Body
i was really astonished about the low end torque this engine produces - moves the heavy Caprice just from a slightly touch on the pedal - it's exactly the goal i had when i planned that swap
D
There are 10 cent resistors that can bypass the VATS.You wouldnt even notice the lock up.I would rather spend my $$ on an S10/Vette converter than a burner or chip.You could also use a stock TPI harness
L
Discussion Starter #13
sure, you can use the stock harnesses and bypass the VATS...
i have done everything of that, and always ended the way i described - custom chip, Painless harness... anything else isn't reliable enough for a daily car.
Discussion Starter #15
yeah, cool swap for sure
you can replace the fan shroud for one from a dual electric to clean things up a bit.
Don't TPI motors run out flat at higher RPMs?
D
Discussion Starter #16
yup..4500 for the stockers and a bit more with the aftermarket ones..
Discussion Starter #17
where is the redline for the TPI?
Isn't it 4500 for TBI motors?
D
Discussion Starter #18
no, but the power curve goes down after 4500(usually) withb the LTR's
1 - 20 of 20 Posts
