Does anyone have a source for a new connector "pigtail" for the engine temp sensor (the sensor between #6 and 8 plugs)?
If not, is there any reason I could not just use an aftermarket connector to one of the pins on the sensor? From looking at the old pigtail, it looks like the middle pin is just a guide as the hole in the pigtail is just plastic. However, it also looks like, from using my multilmeter, that the two pins are connected inside the sensor since I get no resistance between the two pins. So I wouldn't think it would matter which pin I connect to.
Thanks for any help or clarification.
