HI Guys,
It is getting cold now, so I put my heat, and as you expect No ht ait\r is coming, so itool the car to the mechanic, did the radiator flush, still no heat, so the guy siad it is the thermostat, guess what there was none in the car, just the gasket, so got a new one, and kept the car runing for anout 15 minutes, still no heat, but the mechanic is telling me that even the engine is not getting hot, and the water coming through the bleeder is cold...Any suggestion? The only difference I notice after the thermo change is that the temp guage moved form c "as it was always at" to 2 lines above ....
ANy Suggestions for both hengine, and heat.
And yes, my car is 95 Roamaster sedan, with less tha 11K on it
Did you use an LT-1 specific thermostat? Stock one should be a 180.
Most heater problems are due to a clogged heater core. You need to flush that.
I bought it from Autozone.,..it is duralast for 10 $, would that make a diffrence?
NO it wasn't done, how would you do that, I guess I ill do it on my own if it is not a big deal
